I thought I would share a recent internal discussion between Blue Prism consultants.
One of my colleagues could not send specific keystroke to a Mainframe emulator using our built in hllapi interface:
Firstly - if you are having issues with the Mainframe interface, make sure you have read your Mainframe Automation guide on the portal first.  Sending keystrokes to a mainframe are slightly different, you either just us a write stage for sending text, or you use a navigate stage with global send keys to send control keys (such as @E or {ENTER} for sending enter).
If there is a specific key that you are unable to send it is most likely the cause of how the hllapi interface has been implemented on the mainframe itself - all that Blue Prism does is wrap that standard interface.  You will have two potential options to send the problem keystroke:
1. Create a second Win32 windows interface just for attaching to the mainframe and sending that one keystroke.  I had a problem sending the £ symbol once and this is the technique I used.  Every time my object detected some text containing the £ symbol needed to be sent it called my second windows object to send the £ symbol using Global Send Keys.
2. Your other option is to play around with the keyboard mapping within the mainframe emulator itself.  Some mainframes have a feature that allows you to map a characcter to a different keyboard key - so simply map the problem key to a different keyboard key that you are not using and experiment with sending that keystroke.
