08-05-20 06:09 AM
11-06-20 11:45 AM
When an application runs in one of the external modes, a separate Process is started to control the target application and isolate it from the main Process. Blue Prism maintains a connection to this Process, which it uses to send commands to and receive responses from the target application.
However, if the target application becomes unstable or freezes, this can bring down the separate Process and cause Blue Prism to lose connection with it. As a result, the following error message (or similar) is displayed:
"ERROR: Internal : AMI error occurred in WaitStart Stage 'Wait for startup' on page 'Startup' - External AppMan reader thread exited before response from query."
15-06-20 02:40 PM
17-05-23 07:46 PM
Hello John
Thanks for the information.
I am facing the same issue with one of the processes. Bot fails with this error message in Production.
Scenario 1. Bot fails with this exception. All I do is launch and close Chrome manually from Desktop and trigger the bot and it works just fine. I have tried triggering the bot without launching Chrome but it fails.
Scenario 2. If I launch and close Chrome manually right before the bot schedule time, it works just fine as well.
This is some weird behavior I am seeing because the bot launches Chrome from Program Files and not sure how does it matter if I launch Chrome manually from Desktop and then I came across this thread. Would you please help me what can I do to fix this issue.
Rachana
