Active Work Queue and Scheduler Fail to Trigger Process
29-05-20 01:28 AM
Hi Blue Prism Community,
I have been building a process myself to test the work queue capability of Blue Prism 6. Architecturally, I would like a process to be triggered to run when an item is added to a queue. I understand Active Work Queues is designed to do this but no matter what settings I try I can not make the Availiable Resources number tick above 0.
Previously I had tried to get a process to run daily off a scheduler but there was no luck there either.
Should probably note that in my current infrastructure set up I am running a local instance of SQL Server and developing on the same computer I am trying to run the processes off. Is this an issue?
Happy to provide any other information as required.
Thanks!
Stephen Lew
Australia/Sydney
Thanks!
Stephen Lew
Australia/Sydney
0 REPLIES 0
