Adding work to a queue using external code
19-02-18 04:26 PM
Hello, I would like to know if it is possible to add some work to an existing work queue using external code, for example C #. My aim is to add work without using BP, I know the use of a BluePrism Web Services, but it's not worth use a BP license for add work ... I've checked some of the .dll but have not found nothing clear. I'm trying to create a Console App in Visual Studio. Some help please. Thanks in advanced!!
20-02-18 02:29 PM
Technically it's possible but it's not something we recommend or can advise on. The DLLs are not an API and you should not attempt to guess, the results could be disaster.
