Advice to our change plan.
YasuyukiKoike
Hi guys.
I have a plan to change our Blue Prism platform to resolve the Blue Prism environment upgrade issues.
(See attached file)
It was designed to remove outage time for upgrades.
Please let me know any advices for this plan freely.
Yasuyuki Koike
Specialist
Toshiba IT-Services.corp
Asia/Tokyo
JerinJose
Level 10
Hi Yasuyuki,
The plan looks good. it can be improved. it might work well with small environments hosting <100 bots if your production environment has more bots i would recommend you to introduce a layer 4 load balancer In front of the Application servers. also consider the system requirements for version 7 there is changes is supported OS in version 7 if your current environment is configured in windows 10 you can work smoothly with this plan else you might face some difficulties testing your process across the old and new versions
Jerin Jose
Technical Product Owner
EY
*"If you find this post helpful mark it as best answer, .*
Hi Jose,
Thank you for comment. I will design include L4 load balancer if I have to scale our production environment.
Yasuyuki Koike
Specialist
Asia/Tokyo
