Hi Experts,
We are in a phase of migrating from
Blue Prism V6.4 ~ IE to Blue Prism V6.10.4 ~ Edge.
We are facing below two issues with our current environment (Blue Prism V6.10.4 & Edge V104.0.1293)
1. The Extension used to remove by itself from the Edge even after adding manually.
2. For some server, even if the Extension is present, we are facing issue with "
Attach" the target application.
Also kindly suggest on to choose 1. Edge ~ Blue Prism or 2. Chrome ~ Blue Prism. Bit explanation on this will be more helpful.
Thank you.
Simanchala Pattanayak
Lead Solution Advisor
Deloitte USI
Bangalore
