Attach issue while upgrading to v6.9 (from v6.4.2)
HongJooChoi
Hi, all.
Is the following a known issue?
I come across the Attach action is not working after having upgraded Blue Prism from v6.4.2 to v6.9.
The error message is "the given key is not present in the dictionary". The application to attach is IExplorer.
The attach action has been using two parameters, "process name" and "windows titles", but after the version upgrade, it has spit out the error as above. The problem was solved anyway by using one more parameter, "Process ID".
I was aware that the code stage complier has been upgraded from v6.8 but is this issue related with it? or is it something we missed?
Best regards
HongJoo Choi
esaugos
Hi @HongJooChoi,
Can you please share the screenshot for better analysis of the issue your are facing?
Saurabh Goswami
RPA Architect
Ericsson
Saurabh Goswami
Hi, Saurabh
It happened I was working on site and
I'm afraid I couldn't take it out of the site due to security reason.
HongJoo Choi
