13-11-24 02:01 PM
All,
I look for a tool in BP or ourside to automate "bot testing" period during a mass project, please advice back
ERCAN FIRUZE
15-11-24 08:39 PM
Please provide more context. There isn't enough information in your post for anyone to help.
3 weeks ago
Hi again,
I want to learn if we implement new release of BP ie 7.4 then do we need to test all bots in PROD or do we need to make only regression test to make sure that all bots will work as usual ?
In other words, what is the best practices to follow after a new Release implantation in BP ?
Thanks a lot in advance
3 weeks ago
Hi Ercan,
Thanks for clarifying what you're looking for here. Best-practice guidance for preparing for an upgrade of Blue Prism Enterprise can be found in our Knowledge Base article here, with links to our 'Upgrading Blue Prism Guide' which outlines the primary upgrade considerations and what you can expect with regards to testing efforts, along with high-level upgrade and regression testing strategies.
As far as your original request, perhaps others could share their experiences in this thread regarding any tools they may have used to assist with the Blue Prism upgrade process.
3 weeks ago
As per my experience, most of the Blue Prism Stages will remain unaffected, at max you can see 10% stages may need changes if you are using the standard Objects provided by Blue Prism.
If you have custom build objects then you have to take care.
Also suggested by steven, refer Blue Prism Upgrade Guide.
