Hi Justin,
Pop-ups can be a nightmare in web services, now I am going to assume your using iexplore (as Blue Prism standard browser).
Pop-ups within de-bug often do appear as spy-able via standard techniques within the object you're working with i.e. I am working in an iexplore object, and a download bar appears at the bottom, and Blue Prism will let me spy it within this objects application modeller.
This is often quite misleading and will fail when in control without warning. The easiest way we have solved this within our own Centre of Excellence is a range of "Utility" objects all built for the standard pop-ups you face when working with a browser:
- File downloads
- File uploads
To name the simplest, these are independent objects with Win32 spying that attach themselves to the browser. It's tedious at first,but it does mean that you have robust, reliable objects for all future projects.
Hope this is of help,
James
James McLintock
Process Analyst and Developer
