08-09-21 08:28 PM
08-09-21 11:49 PM
08-09-21 11:49 PM
09-09-21 03:41 AM
09-09-21 07:57 AM
13-09-21 05:22 PM
Blue Prism saves connection configuration in this file: C:\ProgramData\Blue Prism Limited\Automate V3\Automate.config
Other config files may be there depending if this machine was set up as runtime resource and depending on the version of Blue Prism installed.
By default 'normal' users don't seem to have edit rights on those folders and therefore Windows asks for elevated permissions.
Since this can become a little combersome to always type user/password of the admin user (in case admin users are even allowed in your company), we asked to grant full access to folder C:\ProgramData\Blue Prism Limited\Automate V3\ and everything below.
I would not recommend switching to user and run Blue Prism application as admin user.
First this is bad practice, there is a reason why normal Windows users don't have admin rights.
Second, in this case Blue Prism will run as admin user, which might have different rights, access (eg personal network drive), runtime behavior, ... It might not be possible to spy applications started in different user contexts.
