Hi SriGuru,
Blue Prism officially started supporting web based automation on Edge since v 6.8 using it's own spying mode called the "Browser Mode". You are on ver. 5 which is really old now and I think your best bet would be a version upgrade only as. If you are still on that version your best bet is Win32 mode, UI or Region mode only but obviously you can't really say the result is going to be perfect.
Coming to the second part, IE being decommissioned means no more support will be provided for IE and most of the applications will be migrating to latest browser technologies so ultimately businesses would need to move their applications on those framework.
Website:
