Bot and Human working on same file
19-09-22 05:51 PM
Hello - What are the best practice for bot working on a file which human is also updating and of course human can open the file at any time of day.
Neeraj Kumar
Technical Architect
Neeraj Kumar
Technical Architect
6 REPLIES 6
19-09-22 10:02 PM
Hi @Neeraj Kumar,
I would say the general rule of thumb is don't do this. 🙂 However, it comes down to your use case and the software/platform that's involved. Many software packages will not allow more than one person to edit a file at one time because they're not designed for concurrency. Are you talking about something like Excel or something else?
20-09-22 07:57 AM
Hello @ewilson - Max time i tried to follow general rule of thumb to avoid chaos 🙂
Yes, i am talking about Excel File.
Neeraj Kumar
Technical Architect
Neeraj Kumar
Technical Architect
20-09-22 08:24 PM
Hi @Neeraj Kumar,
Are you talking about a shared excel file which is available on the sharepoint or a local version of it since you 2 people can't work on same file at the same time.
Manpreet Kaur
Manager
Deloitte
Manpreet Kaur
Manager
Deloitte
27-09-22 08:01 AM
Hello @ManpreetKaur1 - Yes. i am talking about Excel file placed in a share drive where BOT and Human can update the excel.
Neeraj Kumar
Technical Architect
Neeraj Kumar
Technical Architect
27-09-22 09:24 AM
Hi Neeraj ,
You can try below scenarios .
1)Lets say the Human can update the document before the scheduler kicks in there by when the BOT starts the schedulers no issues .
2)If the Human is updating the file during the scheduler time-- try to Defer the queue item which has the dependency on the File and try after Defer time .
Hope this helps .
Best,
Satish Gunturi
Satish Gunturi
Hope this helps .
Best,
Satish Gunturi
Satish Gunturi
27-09-22 11:18 AM
Hello Satish - thanks for your reply.
i am considering these workaround only. Once Human is done updating the file then i am running the bot again to pick the value.
My question was more around solution to problem.
Neeraj Kumar
Technical Architect
Neeraj Kumar
Technical Architect
