15-06-22 08:46 AM
16-06-22 09:10 AM
16-06-22 02:39 PM
Hi Roshini,
Seems like you are not using chrome rather you are using some file to access something.
We would request you to try with other modes.
if that is not helping please check whether you have installed Extension or not and try restarting your machine.
17-06-22 03:52 AM
17-06-22 10:17 AM
22-06-22 07:57 AM
12-07-22 12:04 PM
a week ago
It appears that I can now no longer spy locally saved HTML files with Browser mode after MS Edge updated to version 128.0.2739.54
I do have a solution, which is spying with UIA, but it would mean quite a lot of redevelopment. Its not as user friendly to read HTML with UIA, as for example there is no "Read Table" option available. I can do "get row" with UIA and then append rows to build a table, but it throws exceptions for empty rows.
a week ago
Today Microsoft Edge updated to version 128.0.2739.63, and I can use Browser mode again for locally stored HTML file. Problem solved.
