Capture result from VBScript (SAP automation through scripting)
02-09-19 03:30 PM
Dear all,
I have a question related to SAP automation through usage of VBScript. I have my process in SAP in a vbscript and I 'play' the script through the 'Utility - Environement : Start Process' VBO where my application is the path to my SAP VBScript and the Arguments the variables I want to pass to the script.
This works like a charm, but the issue I am having is that I am not able to return the result of the script to BluePrism. Whenever there is a success, or more imporatntly an error I want to know for error handling purposes.
Do you have any suggestions on ways to execute the script while also being able to capture the result of the script? Usually I would use something like
Nanne van der Wal
Advisor
EY
Europe/Amsterdam
"WScript.StdOut.WriteLine <SAP_Status>"
Best,
Nanne
Best,
Nanne
Nanne van der Wal
Advisor
EY
Europe/Amsterdam
03-09-19 06:25 AM
Have you tried using Utility - Environment : Start Process Read Std Err Std Out
Gopal Bhaire
Analyst
Accenture
Gopal Bhaire
Analyst
Accenture
03-09-19 08:20 AM
Yes, I have tried that. Then I get an error message that the program is not suitable for that command. Not sure how to deal with it, or what the issue is.
Nanne van der Wal
Advisor
EY
Europe/Amsterdam
Nanne van der Wal
Advisor
EY
Europe/Amsterdam
03-09-19 09:25 AM
Try Program name as cscript, argument as path to vbs followed by arguments for vbs.
Gopal Bhaire
Analyst
Accenture
Gopal Bhaire
Analyst
Accenture
03-09-19 09:43 AM
You are the hero of the day!! Works like a charm 😄 Thanks a lot or your help!
Nanne van der Wal
Advisor
EY
Europe/Amsterdam
Nanne van der Wal
Advisor
EY
Europe/Amsterdam
