Connecting to Postgress SQL Database
BoniSahithi
Hi
I am working on a POC that uses MS Outlook VBO to fetch mails everyday into a collection and posting them to a  Postgress SQL database. Can someone help me which VBO I need to use to connect to my Postgress SQL DB instance and what db details are needed to complete the post...?  Appreciate your help.
Boni Sahithi
ewilson
Hello @BoniSahithi,
There is a PostgreSQL VBO available on the Digital Exchange. You can find it here. Please refer to the user guide for specifics about how to set it up.
Hi Eric,
Thanks for the help. @ewilson Is the release file in the link provided by you the VBO? Is there any other VBO that can be used. I saw some links mentioned OLEDB-SQL Server can also be used.Thanks again
Boni Sahithi
If you want to connect specifically to the PostgreSQL database you'll want to use the PostgreSQL VBO. The OLEDB and SQL Server VBOs are for connecting to other types of data sources like an Access database or a SQL Server instance.
