Connection to unsecured Resources is disabled - Control Room Resources
mkumar407
Level 7
Connection to unsecured Resources is disabled - Am getting this error in control room and all resources are appearing offline. Please advise.
System > System > Settings > Runtime Resource Connectivity Have you got 'Require secure inbound instructional connections' ticked?
mkumar407
Level 7
Thanks John, above settings was ticked. We unchecked it and all runtime resources were appearing online. Please advise if we want to keep above settings checked and then connect to runtime resources. Do we need to install any certificate?
Yes, if you look in the Help it describes this setting: Specifies that Blue Prism clients and Blue Prism Servers will only be able to establish connections with Runtime Resources that are configured to apply certificate-based encryption. Additionally, where this setting is enabled, Runtime Resources will only be able to establish a connection with the platform if they are configured to apply certificate-based encryption.
mkumar407
Level 7
Thanks for your help John.
