Converting VBA Code to VB to Use in Code Stage
SeanScudellari
Hello, I have some VBA code I wrote to get all bullet point text in a Word document and I would like to use this within a code stage in Blue Prism to get all bullet point text within a text variable or preferably, a collection variable. The VBA code runs fine within Word, but I'm having trouble converting the code into VB to work within Blue Prism.
Here is  the VBA code:
Dim Para As Paragraph
For Each Para In ActiveDocument.Paragraphs
       If Para.Range.ListFormat.ListType = wdListBullet Then
       MsgBox Para.Range
End If
Next Para
The main issue I seem to be running across is "paragraph" is not a valid data type in Blue Prism that can be stored in a text or collection variable. So I'm a bit stuck on how to handle this. Also, I know that "wdListBullet" corresponds to a value of 2 for its enumeration, so I believe the value 2 needs to be used instead of "wdListBullet" within the code stage. Any help would be greatly appreciated.
Thank you!
Sean Scudellari
13 REPLIES 13
PabloSarabia
Level 11
Hi @Sean Scudellari
I think that BP is not recognising the Paragraph data item cause you don't have added the Interop dll
Try checking this configuration for the VBO:
I think, the best way to this is to create a new page in this VBO: https://digitalexchange.blueprism.com/dx/entry/3439/solution/ms-word-vbo
This code does not return any compilation errors but I cannot test it.
Dim doc as Object = GetDocument(handle,documentname)
Dim range As Object
'do something
End If
Next Para
Try with this!
Hope this helps you!
Pablo Sarabia
Solution Manager & Architect
Altamira Assets Management
Madrid
Thank you @Pablo Sarabia! I was created this custom action within the Microsoft Word VBO as you mentioned. This is what my configuration looks like in the Word VBO:
I believe this matches your picture, correct? Or is there anything else I need to change within this configuration? Also, I'm using Word 2010. Perhaps this interop dll is not compatible with Word 2010?
Sean Scudellari
Hi @Sean Scudellari
​I think it doesn't matter which version. What error do you get when you create a page within that VBO?
Is the exact code you use the one you indicated above?
Bye 🙂
Pablo Sarabia
Madrid
Hey, @PabloSarabia, this is the error I'm getting. I had to make a couple adjustments to your code because I was getting some additional errors, but now I'm just left with this one error that I'm not sure how to resolve. Do I need to create an input for Paragraph?
Thank you.
Sean Scudellari
Hi Sean,
Try using this code at line number 5. It should ideally work:
Dim Para As Microsoft.Office.Interop.Word.Paragraph​
WonderBotz India Pvt. Ltd.
@PabloSarabia @devneetmohanty07
Thank you, Devneet. I updated my code and am no longer getting an error, however, the output I get is "System.__ComObject"
Here's the code I now have:
I believe I need the .ToString() in the result or else I'll get an error, however, this is causing my result variable to have an output of "System.__ComObject"
I feel like I am pretty close to getting this and just need to find a way to get the values in the output.
Appreciate your help!​
Sean Scudellari
Hi @Sean Scudellari
To get the text from a paragraph use this:
result = Para.Range.Text​
But, with this you only get one of the texts. Do you want to get a collection of all the texts or something similar?
Bye 🙂
Pablo Sarabia
Madrid
Hi Sean
You might find this page useful for any future vba conversion to vb Converting Code from VBA to Visual Basic .NET | Microsoft Docs
Michael ONeil
Technical Lead developer
NTTData
Thank you @Pablo Sarabia! That worked! But yes, getting each bullet point within a collection would be great.
Also, if I wanted to extract only the bullet points from a certain section of the document, how would I do that? The range of each document I need to process will be different (each will have a different number of characters, so would be hard to use a 'start' and 'finish' input variables within a range). However, the text that comes before and after the specific bullet points will be same in each document.
For example, the document would look like this:
Section 1 - Header
  • Bullet 1
  • Bullet 2
  • Bullet 3
Section 2 - Header
I would like to get the bullet point text only between section 1 and section 2 of the document, but the section 1 and section 2 may be in a different range within each document I need to process, but their sections headings/titles will always be the same.
Thank you so much for the help, I greatly appreciate it!
Sean Scudellari
