13-01-21 12:12 PM
Hi All,
I would like to know if there is any limit for adding properties to an existing credential within the BP Credential Vault (Blue Prism 6.6)
I would need to create a credential containing more than 700 properties, does anyone know if there is any limit? Or if there is something that I should take as a potential risk?
Thank you very much for your help
Best regards,
Best regards,
13-01-21 03:59 PM
In the Blue Prism database schema a credential property is related to the of the credential table as both these tables have a unique identifier as their primary key it is possible to store in total 340 undecillion (3.4 X10^38) records in total in both tables. Just because you can however doesn't mean that you should. There will be a number of things you need to consider when maintaining acceptable performance, 700 credential properties is a lot however it also depends on how many credentials with 700 properties you require, how frequently they are accessed, from how many processes and concurrency to name a few.
As always I would test this level of complexity in a lower route to live environment to ensure you can achieve sustainable levels of acceptable performance.
Chris
Chris
13-01-21 02:31 PM
That's a lot of properties! I think it's safe to assume there is no upper limit on the number of properties that may be added to a credential, as long as each one has a unique name. The property values are encrypted in the same way as credentials, so there wouldn't be any additional risk to using properties instead of credentials.
13-01-21 03:59 PM
Chris
Chris
