Custom XPath not working properly
NaveenKumar5
I have created my own custom xpath in chrome browser automation everything working fine but in wait stage, if i wait for element it always condition is true even particular element not present in webpage.
in Application Moduler i have selected only Path/XPath attribute.
Example Xpath : //div[text()='Log In']
Blueprism 6.10.1
Q : Why wait stage condition is always true even if element is not present in webpage when i use custom XPath.
Naveen Kumar
Hi Naveen - it's bug that will be fixed in the next release. The workaround is to tick one other attribute (such as Web Element Type) in addition to the xpath attribute. I don't know why that fixes it, I found it through experimentation when I had the same problem as you.
John Carter
Professional Services
Hello ,
Web element Type need to used along with Web Path only before version 6.9.  Fixed as bug in 6.9 Thanks for sharing that bug still persist in 6.10.1 as well.
Neeraj Kumar
Technical Architect
