Define resourcePC fo debug a process
19-02-18 05:53 PM
hi,
It is possible to set the resourcePC to debug a process? I need to run the process in debug mode on another workstation
bye
maurizio
19-02-18 08:53 PM
I'd love to understand your use case - you want a resourcepc on another worksatation that runs a process in debug mode instead of as a resourcepc session. It all sounds very wrong to me?!
21-02-18 08:24 PM
hi, i have two PC:
pc 1 used to develop a process
pc 2 used as resourcePC
i'd like to debug a process on pc 2. You've hit the problem, it is possible to do?
thank you for your answer
22-02-18 03:33 PM
Realistically you can only debug via the diagram. A process running via control room cannot be debugged on the fly.
