Difference between 'Automatically set exception at cleanup' / 'session end'
NaveenRPA
Hi Team,
What is the difference between 'Automatically set exception at cleanup' and 'session end'.
If item is marked with 'Automatically set exception at cleanup' that time it is retrying, why it is not retring when item is marked as 'session end'.
Thank you.
naveen k
Rambo27
Level 8
Hi @naveen k,
"Automatically set exception at clean up" is set up by Blue Prism if the queue case is not specified as an exception or completed. If the machine restarts while the Process is in execution, this might occur. The process gets terminated before declaring the previous item or it takes a separate case without declaring the previous one.
Shikhar Mishra
RPA Lead
Infosys
Shikhar Mishra
RPA Lead
For the Auto Retry, you'll have to set up your work queue accordingly it won't retry automatically.
17096.pngSo in this example, BP would force retry items for 3 items.
As Shikhar stated correctly when you leave an item hanging in the locked state and does to mark it as complete/exception those items will be marked as Auto Clean Up.
Session End is again altogether a different thing. Session end means the process that you're running on a bot from the control room is completed which means your session is ended.
Thanks & Regards,
Tejaskumar Darji
Sr. Consultant-Technical Lead
