Drag and Drop
padmaja_ravipat
Hi Team, I have to select list of elements from one window and drag the same from one window to other window. I tried using drag and drop options available in application modeller, but it seems nothing is happening. How could it be done. Could any one help. Thank you..
TomBlackburn1
Level 7
Are you using surface automation (regions)?
Yes, as indicated by Tom - you are using a Surface Automation technique - so the lessons from that training need to be applied (the window needs to be activated first etc). Other options that might work for you are keystrokes such as shift and down keys etc.
padmaja_ravipat
Hi Tom and Denis, Thanks a bunch for your response. Earlier i didn't try surface automation technique. After your response, I tried Surface automation technique and can be able to perform drag and drop operation.
