Drag and Drop
TomBlackburn1
Level 7
I'm trying to drag an element and drop onto another element. I'm assuming that the 'Start Drag' and 'Drop Onto' within a navigate stage should be used. Can anyone explain how to use the actions? It doesn't seem to actually 'do' anything. I've performed the steps manually and the application accepts my manual actions. The elements were spied in region mode as I'm interacting with a Citrix App. I've tried combining them into 1 navigate stage - no joy. I've tried to separate them out into 2 navigate stages - no joy. I've tried to put a wait stage in between these 2 stages - no joy. Am I missing something? Thanks.
The success of using Drag and Drop is dependant upon the application itself, it is not guaranteed. You may have more luck using the Start Drag and Drop Into actions available for Regions. For more about how to use Regions (Region Editor, activating windows to ensure focus etc.), please refer to the Surface Automation training.
