Drag and drop issue clarification
PankajWalia1
​hi,  We are experiencing an issue with drag and drop where it starts to "drag" from the starting coordinates but then stops in between before the drop action is called. As a result we are getting much smaller box around the text region for linking with the publishing application . The process works with activating PDF, finding the coordinates of the text (top left and bottom right). we have two dynamic regions with the start and end values of one region  equal to top left coordinates and of the region being bottom right respectively. In the 'Start Drag' action  we are specifying the first region with some pause after drag, followed by 'Drop Onto'.
The behavior is that it starts to drag from the coordinates specified but ends in between creating a much smaller square instead . And then once drop action starts we see the cursor moving to the end location . So basically I think what we are looking to see why drag is not able to continue till you drop and what we can do to fix the issue .
Hoping to get you response on this issue soon..
thanks
Pankaj Walia
Architect
Wipro
America/New_York
PankajWalia1
Hi, Has anyone experienced the same issue with drag and drop? What we are seeing is that drag starts but stops in between, and then drop moves the cursor to the bottom right coordinates . The result is that the box we are trying to create around the region is much smaller than the entire region. Anyone with any tips on how to solve this issue , let us know.
Pankaj Walia
Architect
Wipro
America/New_York
rabbanir
Hi Pankaj,
I know this is an old post but it seems I am having the same problem; I am trying to get it to drag a scroll bar but it seems to only go half way. Just wondering did you ever resolve this issue?
