Error when using downloaded MAPI
PeterBly
I have downloaded MAPI 2.0.6. It appear the installation went OK. I changed the path pointing to BluePrismMAPIExAutomation.dll to the Program Files (x86) folder. When refreshing the MAPI object, I had no errors ( there were 2 before changing the path). However, when I use one of the actions from the new MAPI object, I get the message: Internal : Could not execute code stage because excpetion thrown by code stage: Could not load file assembly 'BluePrismMAPIExAutomation, Versoin-2.0.6.0, Culture=neutral, PublicKey Token=null' or one of its dependencies. The system cannot find the file specified. I'm sure that I hae the correct path. Any ideas? Thanks
Make sure the process is 'aware' of the latest changes to the object, either by pressing Refresh or by closing and reopening the process.
PeterBly
Thanks John. I did try that. I even tried again today, after having shut BP down. Same result.
SandeshDivate
Try moving all dlls and tlb files from C:\Program Files (x86)\Blue Prism Limited\Blue Prism Automate to C:\Program Files\Blue Prism Limited\Blue Prism Automate  (if your BP is installed in Program Files and not in x86) Make sure MAPIEx VBO is referencing the dll path from C:\Program Files\Blue Prism Limited\Blue Prism Automate and not from x86.
