Excel Code Stage OpenText
MelanieWerner
Hi!
I want to open an Excel .xls Data with the Excel VBO "Open Workbook." But the Format for Numbers is not correct. So I can't keep working with the data.
So I added  Open Text with origin to the "Open Workbook" stage code.
Here the Code Stage:
Dim wb as Object = GetInstance(handle).Workbooks.OpenText(filename, Origin:= ("1252"))
name = wb.Name
wb.Activate()
But I get this Error Message:
Internal : Could not execute code stage because exception thrown by code stage: Der öffentliche Member Name für den Typ Boolean wurde nicht gefunden.
But in the Background the xls open correct with the correct Format.
Can someone help me?
Thank you!
Kind Regards
Melanie
Accountant
0 REPLIES 0
