Having both BluePrism v6 and v7 on the same PC
27-10-22 06:43 AM
Hi All,
Currently, I m doing a ver upgrade + migration from v6.7.2 to v7.1.1. Can I have both vers installed on the same machine at the same time? it would be easier for migration activities.
Many thanks
Many thanks
27-10-22 07:19 AM
Hi Andus,
As I currently have two versions installed on my PC (a VDI really) albeit versions 6.5.1 and 6.10.5, I assume the short answer would be Yes. It is however a tricky business with the different databases, so I hope someone can explain how this can be done without messing up the database for one or both of the versions.
Happy coding!
Paul, Sweden
Paul, Sweden
