Help with code stage to find value from Excel column (exact match)
JariKorkkinen
Hello, I have a process where I have to find certain value from Excel sheet´s column, select the cell and write data to that row. Worksheets are very large (tens of thousands rows) and it would be too slow to achieve this with BluePrism´s standard Excel VBO actions so I have created a new action for search. This works well except this returns also partial matches.  Eg. If I search 12345, this considers 1234567 as a match which is wrong. Here is the code [inputs CTS = column to search (number), FIND = value that is searched (text)]: -------------------------------- Dim worksheet As Object Try worksheet = GetWorkbook(handle,Nothing).ActiveSheet worksheet.Columns(CTS).Find(FIND).Select Success = True Catch e As Exception Success = False End Try ---------------------------------- I tried to alter code to return exact matches only but this didn´t work. This doesn´t find anything.   Dim Excel As Object Dim worksheet As Object Dim wb As Object   Try wb = GetWorkbook(handle, nothing) worksheet = GetWorkbook(handle, nothing).ActiveSheet Excel = wb.Application   worksheet.Columns(CTS).Find(what:=FIND, LookAt:=Excel.xlWhole).Select   Success = True Catch e as Exception Success = False   End Try ------------------------------------- Would here be a vb.net wizard who could see what is wrong in the code and help how to get this working correctly?   Br, Jari
Have you tried using the OLDEB VBO to access and manipulate your Excel workbook using SQL?
JariKorkkinen
Hi Denis, Thanks for a tip! I am not familiar with OLEDB so I have to study that and see if that would be a good option to handle massive Excels in the future. Still I´d like to find solution to my code problem because otherwise this code works very well.   Br,   Jari
