How to Run Macros on MS Access using OleDB VBO
KunalDoshi1
How to Run Macros on MS Access using OleDB VBO ?
PabloSarabia
Level 11
Hi @KunalDoshi2
​If i'm not wrong, you cannot use OleDB VBO to execute macros.
This assets gives you the possibility to connect to Access DataBase and execute SQL sentences (Selects to get information or INSERT, UPDATE or DELETE for manipulate information)
I don't know if the question is wrong and you want to know how to work with Oledb VBO.
