How to achieve mouse hovering through blueprism
Sri_Krishna_Cha
I have an application in which if I hover my mouse, it will give additional links. But when I am using focus action in robotics, this is not working.    Any views?
7 REPLIES 7
BordessoullesVi
In application Modeller you not view the link ? (in Attributes ""title"" for ex) ? if yes you can read this param.
Sri_Krishna_Cha
Please see the attached screenshot, the moment I just place my cursor over the Application, it shows me all the list of options available for that specific action, similarly if I place my cursor over the tools, it shows me list of options available . I want to achieve this using robotics. I spied the elements in html mode and selected actions like focus and others.. but nothing is working out. Does that makes sense?
MelissaSuarez_G
Try Global Mouse Click Centre. Technically this doesn't hover over the element but it would simulate using the mouse to actually pressing that option
DesBoyle2
You could use WINAPI to move the mouse into the required position..I use it a lot and it works really well...
AmitKumar7
Hi Boyle, How to use WINAPI in Blue prism? Do you have any guide for same?
GeraldJ
Hi Boyle,   As Amit mentioned. Can you list out the steps for using WINAPI
IvanRaketski
You can also try to use Drop in Navigate Stage to hover mouse to a certain position.
