Hi Kumari Yadav,
Since you are not comfortable with coding and don't want to use loop as well, thus another method you can try is as follows. Although it can be modified as per the requirement and thus I am mentioning the basic layout.
1) You can record a macro in excel itself, which will dedupe the data, with the help of Remove Duplicates. It is very easy to do and you can easily find it on google as well. You can name the macro whatever you want.
2) Call out that macro by using excel VBO in blueprism.
3) Once macro executed, import the data into collection through excel vbo only.
It's very easy to use and don't require any coding knowledge. You can record a macro in a minute very easily,  if you do a search on google.
I hope this would be of some help to you.
Sandeep Sachdeva
Automation Associate
S&PGlobal
