I am unable to figure out how to send a navigation action to a SAP Checkbox.
I was able to identify it fine using the SAP spy mode. When trying to create a navigation action to click on the check box to change its value I noticed there were no available actions for the object.
All I want to do is change the value of the checkbox.
What is the correct way to do this?
John answer is correct. If you want to tick the checkbox in SAP you have to set the value as ""True"", if you want untick set it as ""False""
Rgrds,
L
