10-02-23 03:58 PM
Is there any way to alert when a resource is offline? Sometimes, one of my resources went offline, and I have to run the Task Scheduler task manually in virtual machine to make it online..
Any help is much appreciated.
10-02-23 05:58 PM
Take a look at the following asset on the DX:
https://digitalexchange.blueprism.com/dx/entry/9648/solution/blue-prism-resource-pc-monitor
There are lots of tools and connectors available on the DX. Just need to search for them.
10-02-23 06:38 PM
Hey my friend, I don't know exactly if exist, but, I Use the grafana Pluged in my datasource and I Configureted one alert in this case, is not hard make this, but you need use the solution of Eric 🙂
14-02-23 07:16 PM
Hi @Arunkumar Manoharan ,
Did you try using the solution suggested by @ewilson ?
17-02-23 07:40 AM
Thanks Eric, I have downloaded the asset and source code package as well. I need to see the source code before installing this asset so wanted to know which cs files I have to take a look because each folders contains many cs files.
17-02-23 05:22 PM
Yes, there's a lot of source code there. What specific area of the application are you trying to view?
16-09-24 10:31 AM
hey there,
I have tried to open this page but it says I need to be logged in to view, however I am logged in and can access other pages within DX. Is there a PDF that can be shared at all for this?
Thanks!
17-09-24 08:11 AM
Hi @Chan_Thomas I hit the same issue as you by the sound of it when clicking the above link, but when logged in to the DX and searching on "resource pc monitor" it shows okay.
Hi @ewilson sorry for a possibly dumb question, I skim read the guide and I am unclear on what resource to install this on. Does it need to be on each resource pc to monitor, the Management Server and all resources to monitor added or the IO1 server for production resources?
Kirk
17-09-24 04:57 PM
@Kirk.Russell you can install the solution on whatever machine you want so long as it has a network path the Runtime Resources you will register with it.
Eric
