How to simulate a spacebar keydown
31-01-18 10:48 AM
Can you please help
I have a list here but without spacebar
Key Code
BACKSPACE {BACKSPACE}, {BS}, or {BKSP}
BREAK {BREAK}
CAPS LOCK {CAPSLOCK}
DEL or DELETE {DELETE} or {DEL}
DOWN ARROW {DOWN}
END {END}
ENTER {ENTER} or ~
ESC {ESC}
HELP {HELP}
HOME {HOME}
INS or INSERT {INSERT} or {INS}
LEFT ARROW {LEFT}
NUM LOCK {NUMLOCK}
PAGE DOWN {PGDN}
PAGE UP {PGUP}
PRINT SCREEN {PRTSC}
RIGHT ARROW {RIGHT}
SCROLL LOCK {SCROLLLOCK}
TAB {TAB}
UP ARROW {UP}
F1 {F1}
F2 {F2}
F3 {F3}
F4 {F4}
F5 {F5}
F6 {F6}
F7 {F7}
F8 {F8}
F9 {F9}
F10 {F10}
F11 {F11}
F12 {F12}
F13 {F13}
F14 {F14}
F15 {F15}
F16 {F16}
Keypad add {ADD}
Keypad subtract {SUBTRACT}
Keypad multiply {MULTIPLY}
Keypad divide {DIVIDE}
5 REPLIES 5
31-01-18 11:11 AM
Because in Browser , i want to check a checkbox using spacebar
31-01-18 11:33 AM
Don't worry, I got it , it's too simple that I failed to think about
use: Global Send Key with text values "" "" to check a checkbox
31-01-18 03:18 PM
Why don't you use 'check' action with parameter true?
15-02-18 09:23 AM
where is this 'check' action located? as in, could you tell the business Object?
20-02-18 02:46 PM
If the control type is checkbox, we can use Navigate, use that checkbox as Element, then select check as 'Action'.
