12-07-23 11:01 AM
We are planning to upgrade BP to 7.2. So while testing, we tried to setup Runtime resource.
The state of resource is Idle, but connection is disconnected.
Appreciate any suggestions to resolve this issue.
Sheela Parthasarathy
Assistant Vice President
Deutsche Bank Group
Pacific/Apia
01-02-24 05:56 AM
We are also facing the same issue so have you got any solution?
05-02-25 08:13 AM
I'm currently having the exact same problem.
Unlike the red cross mark when the status is offline, this icon looks like a circle with a cross. This is the first time I've seen this icon.
Restarting all RRs does not change the situation.
AP server information has been added to all RRs hosts file.
13-03-25 03:48 AM
@sumire I update ACR setting to resolve my issue. There might multiple reasons for the issues -> starting from BP instance configuration, RR configurations. Revisit the configurations to bring up RR.
03-04-25 06:39 AM
It turns out that if I press "Cancel" to close the dialog when such a dialog is displayed, communication is blocked by the firewall.
When this happened, I changed the blocking settings and RR worked normally.
a month ago
Hi @Sheela ,
Hope you're doing well.
May I check if you manage to resolve this issue please? We are also encountering the exct issue in BP 7.3.2 after upgrading from v.6.10.5.
Appreciate your response please. Thanks.
