@VratHimbo it worked like a charm. 45 sec became around 3secs which is quite acceptable.
thanks a lot for the help.
here is what we do, hope this helps.
1) we setup object as java application
2) we first launch java application url on internet explorer (set internet explorer path to
Path field and url to CommandLineParams field)
3) detach from internet explorer
4) attach to jp2launcher
5) detach from jp2launcher
6) attach back to internet explorer
after this we are able to interact with everything and speed problem is solved after
"descendtree,ignorenotshowing" command.
Efe Oral
