Login issues
AnupamaLavu
Dear Team,
I am not able to login into trial or learning edition of blue version 7
I am giving username as admin
And password of blue prism login portal.
Plz help with this issue
Attaching screenshot along with this mail.
Thanks & Regards
Anupama
VedSengupta
Hello Anupama,
Did you change the admin user password while setting up standalone config?
Best Regards,
Ved Sengupta
Deloitte India (Offices of the US)
Bangalore | INDIA
------------------------------ Best Regards, Ved Sengupta RPA Developer Deloitte India (Offices of the US) Bangalore | INDIA *If you find this post helpful mark it as best answer* ------------------------------
Hi ,
Yes I changed blue prism portal password and gave the current password still it didn't work.
Anupama
EVIPUTI
The default password validity period is 4 weeks, so although the license may still be valid your password may have expired. Simply reset the password , you can find more info on here.
Vipul Tiwari
Amazon
Dear All,
My issue got resolved.I have unstalled Blue Prism which one was in system
and restalled the issue got solved.
Thank You All
Anupama
Anupama Lavu
Senior Consultant
Iveond Innovation
Hyderabad
