MAPIEx VBO stopped working after BP installation v5.0.30
Hello, Did anyone had same issue that after installing v5.0.30 any action in MAPIEx VBO gives following error: Internal : Could not run the object because one of the code stages has a compile error, use Check for Errors for a list of problems Note: it was working perfectly fine on version 5.0.23 Many thanks!
I had a similar issue today when running a process. When I checked the business object itself, all the functions worked fine after testing. Then I ran my process again and somehow it all worked again. Maybe you could also try running the business object pages separately and maybe this'll fix it for you too.
JoachimGeelen
I have the same error with version 5.0.34, and tried to run the object separately as well. Do you have any other solution?
DesBoyle2
Is latest your Blue Prism Install local or App-v? Also check that the path to the MAPIEx dll is still valid...
