Main frame Application Spying - Ganesh
Hi Team, We are launching the mainframe application through the navigate stage, after launching the session we are unable to spy the pop up of IBM Sign on and we are using mainframe IBM session identifier. Once we try to spy through Win32 mode it is not changing into grid values and the navigate stage is still trying to connect and blinking. We get a exception " Unhandled exception has occurred in a component in your application if you click continue the application will ignore this error and attempt to continue, Cannot access a disposed object" Could you please suggest us information's to resolve this issue asap. Thanks Ganesh Kumar A Wipro Email: ganesh.kumar28@wipro.com
If you want to automate emulator win32 pop-ups you will need a sepearate Windows Object to attach and handle them (selecting Windows Application from the Application Modeller wizard). The mainframe hllapi interface can only interface with the green screen. You cannot have a mix of Win32 and Mainframe in the same object.
