As you are saying, Left CTRL key to be pressed to unlock the stuck session.
you can use send keys or send key events for this action. in send key evens try to pass {CTRL} and in the send keys the value will depend on how the emulator keyboard layout is mapped. Generally ^ key will work for control but still preferred to check the emulator key board layout and then pass the key.
