06-08-20 12:01 PM
I tried to map ShareDrive as network drive.
Do you have any solution for this action?
Kidn regards
Mateusz Wojcik
RPA Programist
Rockwell Automation
Europe/Warsaw
Kidn regards
Mateusz Wojcik
RPA Programist
Rockwell Automation
Europe/Warsaw
07-08-20 06:03 AM
If you need to do this from within Blue Prism you will likely end up using the "net use" command line command, together with the "Utility - Environment" VBO, "Start Process" action to map your network drives.
I have seen customers map network drives by having this command run in a batch file on Windows Startup, so that the Digital Worker can have the network drive mapped before any work begins. Having the drive mapped on windows login is probably the preferred solution, if you always need to have the drive mapped regardless of what process is executing on that machine.
James Man
Professional Services
Asia/Hong_Kong
James Man
Asia/Hong_Kong
06-08-20 06:03 PM
Hi Mateusz,
Could you elaborate on what you are trying to accomplish? Are you looking at using Blue Prism to automate the mapping of network drives?
Cheers
Charles Kovacs
Developer Consultant
America/Chicago
Cheers
Charles Kovacs
America/Chicago
Charlie Kovacs
07-08-20 06:03 AM
James Man
Asia/Hong_Kong
James Man
Asia/Hong_Kong
