Microsoft Steps Recorder (psr.exe) with Blue Prism Attach Problem
20-10-17 03:23 PM
Hi everyone,
I am working on a project releated with Microsoft Steps Recorder (C:\Windows\System32\C:psr.exe) to catch exceptions from processes with screen captures. I finished to development but there is a problem with attach. It could only possible with when you run Blue Prism (Run as Administrator). Otherwise it couldn't attach to start record button. Also it couldn't work when schedule started.
Could someone used Steps Recorder for automation or a program into the Windows\Win32 folder?
One more question, Is that possible to write a batch file for listener to run as administrators? Is it overcome that issue?
Kind regards,
Ferhat Yaraslioglu
20-10-17 08:35 PM
Hi Ferhat,
there is a utility which can create screen shots from within Blue Prism process. It is part of Blue Prism business object and is called Screen Shot. If you write your email I will send it to you.
Zdenek
