Missing Information In Get Path Read Stage
FabioLeonardo
Hello everyone, I'm having an awkward issue automating a web application in Internet Explorer. When I spy a specific button in Application Modeller, Blue Prism identifies its path as "/HTML/FRAMESET(1)/FRAME(2)/HTML....", which is correct. Then, if I use the a Read Stage with Data Get Path, it returns the path without the "/HTML/FRAMESET(1)/FRAME(2)" part. To make things stranger, for another button in the exact same page, the Read Stage returns the Path with the "/HTML/FRAMESET(1)/FRAME(2)" part. In conclusion, two buttons, identified the same way, with the same Attributes marked and in the same page, are returning the path in different ways, one with the "/HTML/FRAMESET(1)/FRAME(2)" prefix and one without it. Does anyone know what is the cause of this and how to fix it? Thanks.
AndreyKudinov
Level 10
This happens because you got frames in your web application, which is like having a page in a page.  Blueprism hides some of the complexity from you, then it is just inconsistent at identifying actual root with frames present. If you need a fix for it - ask support.
