Not able to Integrate AWS Rekognition Skill
KalpeshGujrati
I am trying to integrate AWS Rekognition skill. But after following each and every step of AWS Rekognition user guide I am not able to understand what input parameters are required.
in the user, guide parameters are totally different than in the object. Even the action name is also different.
Please find the screenshot at attached.
Please help me to understand what value I should pass in parameters.
Kalpesh Gujrati
Consultant
EY India
ChrisHogan
It looks like you have selected the WebAPI instead of the VBO. You should use the VBO from your Blue Prism Process. The VBO creates the data payload from your image as well as the custom Authorization token which are then passed to the Rekognition Web API.
Chris Hogan
Senior Ecosystem Architect
America/Chicago
Hi @ChrisHogan
Thanks for replying.
Currently, I am getting an error as Bad gateway. My API/Server is hosted at "Ohio" Even while using the IBM Watson also I am getting the same error.
Please refer the attached screenshots. please help me to fix this.
Kalpesh Gujrati
Consultant
EY India
The AWS region code for Ohio is "us-east-2"
You can find the full list of region codes for various platforms here: https://docs.aws.amazon.com/general/latest/gr/rande.html
Also, I would delete or redact the picture you have uploaded, since it exposes your AccessID and Secret Key.
Chris Hogan
