OLEDB Connection String - ReadOnly File
Nandhakumar
Level 7
Has anyone used OLEDB query to an excel file in a readonly mode? Win10 platform
I have tried few possibilities but didn't work, please let me know if you have done so.
Connection string:
Extended properties: Mode=Read; ReadOnly=True; ReadOnly=1;
I have tried the aboved mentioned properties but did not work.
Nandhakumar C
Technology Consultant
SimplifyNext Pte Ltd
Singapore
Mukeshh_k
Hi @Nandhakumar - Set the connection string  like this - "Provider=Microsoft.ACE.OLEDB.12.0; Data Source=""" & [File path] & """;Extended Properties=""Excel 12.0 Xml;HDR=No;ReadOnly=True;IMEX=1"""  and use this connection string to set the OLEDB connection.
let me know if you face any difficulties doing this.
Mukesh Kumar
Mukesh Kumar
sastharpa
Hi @Nandhakumar
Yes able to work on a protected workbook on Windows 10. What is the error you are getting and what is your AccessDatabaseEngine version, mine is 2010 32bit?
Below connction strings, I had tried,
"Provider=Microsoft.ACE.OLEDB.12.0;Data Source=""File fullpath.xlsx"";Extended Properties=""Excel 12.0 XML;HDR=YES"";"
Also, Extended Properties=""Excel 12.0 XML;HDR=YES;Readonly=True;
L Ganesh Velayudham
VL Ganesh
Tech Arch RPA
Hi Mukesh,
I have tried the suggested changes, but no luck.
Here is the connection string and error message i get.
I'm using MS access db 2010.
I have the same query working for reading the file if it is not opened by users. just included the extended properties to have it read only but not working.
Nandhakumar C
Singapore
Hi @Nandhakumar - I have just tested this myself again - I kept the file open this time and then tried doing an OLDEB connection, open, execute and reading the file and it didn't throw me any such error -
try creating a test excel file with few columns and rows and repeating the steps and see if this happens to your local file as well -
Mukesh Kumar
Mukesh Kumar
