Hi Aseel,
Please check the asset page along with the threads which I mentioned to ensure you have all the pre-requisites in place first as this asset needs additional DLL's to be added in order to work and you might require to download them from
Nuget FeedThis wont be a direct plug and play asset and also I would suggest you to show us the exact errors from your error compiler window to get more details on the same.
WonderBotz India Pvt. Ltd.
Website:
