PDF Adobe Acrobat Pro - Identifying elements with UIA mode
12-03-19 06:16 PM
So I Created a Object for PDF Acrobat Reader and spied all the buttons & Fields using UIA mode.
However some days later the file path location of the Acrobat Reader has been changed to a new location, then onwards my object is unable to identify the elements in the Acrobat Reader, So I Tried spying again with UIA mode, but unable to identify the elements individually.
Please Suggest me on this instead of using Region Mode and Global Send Keys.
13-03-19 05:57 AM
Hi Srikanth,
Try spying elements using AA mode and check if you are attached to correct instance of Adobe Acrobat Reader.
