27-06-19 02:55 AM
Archana Avaragere Mutt
Premex
27-06-19 05:12 PM
For example, you might provide it with this data (The pipes | indicate a separation between fields to make it look like a collection here):
FirstName | LastName | Address | ZipCode
Larry | Stooge | 123 Bakersfield Street | 30021
That collection will get converted to look something like this which will be placed in the body of the message:
{"FirstName":"Larry","LastName":"Stooge","Address":"123 Bakersfield Street","ZipCode":"30021"}
Dave Morris
3Ci @ Southern Company
Atlanta, GA
27-06-19 06:11 AM
Would the following guide be useful. There is a section on page 4 which enlists a POST call using the Web API configuration tool.
https://portal.blueprism.com/system/files/documents/v6.4%20User%20Guide%20-%20Web%20APIs_2.pdf
Thanks and Kind Regards,
Vinay Shetty
Senior Consultant
27-06-19 05:12 PM
Dave Morris
Atlanta, GA
06-08-20 08:31 PM
I'm looking for some blue prism documentation for API services, as right now I'm doing he automation of one financial tool in IBM. Unfortunatelly I'm not able to open the link with pdf file. Can You help me with that.
Thank you in advance
Michal Bezak
07-08-20 08:51 AM
Could you please check if the following steps assist you :
- Login to the Blue Prism Portal
- Click on the Documents Tab
- In the Search Bar type the keyword - API
- If you scroll through the search results, ideally at the end of the first page there is a guide named as "v6.4 User Guide - Web APIs".
Hopefully this helps.
Vinay Shetty
Vinay Shetty
Senior Consultant
11-01-22 10:36 AM
Hi Team,
I am trying to call Twilio API to send SMS which post method. I want to send body parameters like To, From, and SMS text. Not sure how to send the body. I'm referring to this document for web API calls. https://bpdocs.blueprism.com/bp-6-10/en-us/z-pdf/web-api/v6.10%20Web%20APIs%20-%20User%20Guide.pdf
In parameter
In Process-
Its Giving error status code 400 as "21604- A 'To' phone number is required"
Shraddha Joshi
11-01-22 05:14 PM
From the looks of it you're trying to use the Twilio - Phone Numbers connector. If you want to send SMS's you want to use the SMS Messaging Integration for Twilio which is a different connector. You can find it at the following link:
https://digitalexchange.blueprism.com/dx/entry/9648/solution/twilio---sms-messaging-integration
The Twilio - Phone Numbers connector is an asset for managing phone numbers maintained by the Twilio platform.
12-12-23 04:32 PM
Hi Eric Wilson,
I try to update a ticket on EasyVista via an API call (PUT method) but it does not work, it works very well via PostMan but with the action which I created in my web service I have this error :
Internal : Unexpected error Error during Web API HTTP Request
HTTP Status Code: 590
HTTP Response Content: {
"type": "about:blank",
"title": "Internal Easyvista Error",
"status": 590,
"message": "An internal error occurred.\r\n Please try again later or contact the system administrator.",
"correlationId": "657832bd35275",
"instance": "/api/v1/50004/actions/S230131_072"
You Can find more explication with picture
SLIMANE OUZIALA
Consultant
Arondor Capture
Europe/Paris
12-12-23 08:22 PM
Hello @SLIMANE OUZIALA,
I'm not familiar with EasyVista or their API, but looking at the online documentation at the following link it seems the end point you're using doesn't match what their documentation says it should be for the Update Ticket PUT method.
They show the action path as /requests/{rfc_number} where rfc_number is the ticket number.
Perhaps if you share some screenshots of the endpoint test you have in Postman, that might help.
12-12-23 09:15 PM
Hollo Eric,
First, thank you for you help,
I use the same doumetation for this action, but for Validate ticket I have to use .../actions/{rfc_number}
the linke is here : https://wiki.easyvista.com/xwiki/bin/view/Documentation/Integration/WebService%20REST/REST%20API%20-%20Finish%20an%20action%20attached%20to%20an%20incident-request/
Here you can find a copy of my Postman request
Thank you for your help.
SLIMANE OUZIALA
Consultant
Arondor Capture
Europe/Paris
