Launching InPrivate Window Microsoft Edge
AaronHawkins
Hi all,
Can anyone tell me if it is possible to launch an MS Edge InPrivate Window from Blue Prism and if so, how would I go about doing it?
Edge is started using the Launch action, specifying the path to msedge.exe and the URL we want to navigate to.
I have seen that it is possible to update the properties of a shortcut to Edge so that every time that shortcut is used it will always automatically be InPrivate, however, I haven't had any luck applying this to my solution as it launches using .exe and not a shortcut.
Any guidance would be greatly appreciated thanks.
AaronHawkins
Figured it out.
For anyone interested, you simply add "-inprivate" onto the end of your browser path.
e.g.    C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe -inprivate
Using the switches save few clicks and Seconds for bot. . I usually look up in below web site to see what can be leveraged.
https://peter.sh/experiments/chromium-command-line-switches/
Neeraj Kumar
