23-01-23 01:46 PM
Dear Community,
I need your knowledge/expertise.
I have a process, which are using Microsoft Edge for interacting with our Main application. I have observed randomly that our automation is unable to click, read or interact with the mapped Elements in our Main application.
There're days,/runs where the process is working fine, then our automation completes only each second Item in a run.
If I am running the same process in our UAT Environment, everything works well, and all items are process successfully.
If I check the Screen Captures, I can see that the Application is loaded correctly ever time.
The Application/Edge is launched from the Business Object with the BO "Utility – Environment", Action: "Start Process".
Application Modeller details:
Closing of Edge, I am using currently "Utility – Environment", Action: "Kill Process" and I thought after reading few community post, to change it to click close or the"x" of Edge.
System:
Blue Prism 6.10
Microsoft Edge Version: 108.0.1462.54
Blue Prism 6.10 Browser Extension: 6.10.0 (update to 7.x will be in the next couple of months)
Has/had someone similar problems and if yes, how you solve it?
Thanks in advance for your help.24-01-23 09:03 AM
01-02-23 10:06 AM
01-02-23 10:30 AM
